salut !
j'ai filé trouvé i-next via ftp ^^
[code]
Arch Linux
$ yaourt -S i-nex-git libcpuid-git
If you previously installed the i-nex. Before installing i-nex-git is required to remove completely i-nex package with the libcpuid library.
$ sudo pacman -R i-nex libcpuid
AUR GIT: https://aur.archlinux.org/packages/i-nex-git/
Manjaro
I-Nex is in the community repository:
$ sudo pacman -S i-nex libcpuid
You can also install from AUR:
$ yaourt -S aur/i-nex-git
Linux Mint
Installing from Launchpad PPA
Daily PPA:
$ sudo add-apt-repository ppa:i-nex-development-team/daily
$ sudo add-apt-repository ppa:gambas-team/gambas3
$ sudo apt-get update
$ sudo apt-get install i-nex
If you have previously added repository ppa:nemh/gambas3. It is required to remove it and use the repository ppa:gambas-team/gambas3
Stable PPA:
$ sudo add-apt-repository ppa:i-nex-development-team/stable
Stable PPA: https://launchpad.net/~i-nex-developmen ... ntu/stable
Daily PPA: https://launchpad.net/~i-nex-developmen ... untu/daily
Direct Download: https://launchpad.net/i-nex/+download
Ubuntu
Daily PPA:
if you have previously added repository ppa:nemh/gambas3. It is required to remove it and use the repository ppa:gambas-team/gambas3
Stable PPA:
Fedora
For Fedora 20 run the following as root:
$ cd /etc/yum.repos.d/
$ wget http://download.opensuse.org/repositori ... ation.repo
$ yum install i-nex
Source Code
$ git clone https://github.com/eloaders/I-Nex.git
GitHub: https://github.com/i-nex/I-Nex
Master .zip (direct download): https://github.com/eloaders/I-Nex/archive/master.zip
Master .tar.gz (direct download): https://github.com/eloaders/I-Nex/archive/master.tar.gz
à bientot
nicky
