ping aléatoire
ping aléatoire
Message par priv123 » 18 Avr 2020 23:54
Salut.
Je suis sous telenet à 300mb téléchargement et 30m envoie. (offre business fibernet)
Pendant les téléchargements et les testes débit, j'ai bien ce que offre telenet.
Mais dans les jeux le ping est vraiment instable.
Je suis bien seul et en filiaire sans rien d'autre en arrière plan:
ping ping.ovh.net
PING ping.ovh.net (198.27.92.1) 56(84) bytes of data.
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=1 ttl=55 time=25.7 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=2 ttl=55 time=18.8 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=3 ttl=55 time=11.9 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=4 ttl=55 time=13.0 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=5 ttl=55 time=25.9 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=6 ttl=55 time=13.3 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=7 ttl=55 time=12.5 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=8 ttl=55 time=13.7 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=9 ttl=55 time=14.8 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=10 ttl=55 time=13.9 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=11 ttl=55 time=12.4 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=12 ttl=55 time=20.1 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=13 ttl=55 time=13.8 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=14 ttl=55 time=26.1 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=15 ttl=55 time=14.3 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=16 ttl=55 time=12.9 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=17 ttl=55 time=19.4 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=18 ttl=55 time=13.5 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=19 ttl=55 time=13.1 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=20 ttl=55 time=25.2 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=21 ttl=55 time=13.7 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=22 ttl=55 time=21.4 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=23 ttl=55 time=32.6 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=24 ttl=55 time=13.6 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=25 ttl=55 time=12.0 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=26 ttl=55 time=14.1 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=27 ttl=55 time=23.1 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=28 ttl=55 time=14.7 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=29 ttl=55 time=14.6 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=30 ttl=55 time=12.6 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=31 ttl=55 time=15.3 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=32 ttl=55 time=13.1 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=33 ttl=55 time=16.1 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=34 ttl=55 time=13.3 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=35 ttl=55 time=13.6 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=36 ttl=55 time=14.0 ms
^C
--- ping.ovh.net ping statistics ---
36 packets transmitted, 36 received, 0% packet loss, time 35067ms
rtt min/avg/max/mdev = 11.857/16.448/32.642/5.103 ms
quelques minutes plus tard:
ping ping.ovh.net
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=1 ttl=55 time=20.0 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=2 ttl=55 time=17.4 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=3 ttl=55 time=11.6 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=4 ttl=55 time=12.9 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=5 ttl=55 time=13.9 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=6 ttl=55 time=16.6 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=7 ttl=55 time=26.3 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=8 ttl=55 time=13.8 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=9 ttl=55 time=14.1 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=10 ttl=55 time=20.4 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=11 ttl=55 time=20.7 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=12 ttl=55 time=13.7 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=13 ttl=55 time=20.2 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=14 ttl=55 time=14.8 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=15 ttl=55 time=22.8 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=16 ttl=55 time=24.2 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=17 ttl=55 time=12.3 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=18 ttl=55 time=13.3 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=19 ttl=55 time=12.8 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=20 ttl=55 time=16.7 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=21 ttl=55 time=14.4 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=22 ttl=55 time=12.0 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=23 ttl=55 time=14.1 ms
64 bytes from www.ovh.com (198.27.92.1): icmp_seq=24 ttl=55 time=20.4 ms
^C
24 packets transmitted, 24 received, 0% packet loss, time 23045ms
rtt min/avg/max/mdev = 11.613/16.639/26.312/4.130 ms
C'est très génant pour les jeux.
La ligne sous proximus offre 6-7 de ping (avec la ligne fibre mais cuivre maison) (ou 13 de ping en vdsl2) et vraiment énorme stabilité jour et nuit.
J'avais le même coup avec numéricable/sfr, (à l'époque) j'avais même fais changer le câble blanc entre la ligne rue et le modem ce qui a été sans résultat.
Je voulais savoir quelles sont vos valeurs à vous pour le même teste, pour savoir s'il s'agit de telenet ou de ma ligne/quartier.
priv123
Message(s) : 22
Re: ping aléatoire
Message par MisterG » 19 Avr 2020 00:23
C'est quoi le problème avec ton ping ? Je vois un premier max à 32 et le deuxième max à 26.
De quel jeu parles-tu ?
MisterG
Message(s) : 1240
Re: ping aléatoire
Message par priv123 » 19 Avr 2020 00:49
Le jeux est cs:go.
C'est à la manière de jouer que ça influe énormement.
Imaginer une voiture à 80 km/h sur une autoroute, vous devez tourner un virage à cet vitesse, imaginer qu'on tapote le frein aléatoirement pendant ce virage, on c'est plus trop comment y rouler, dans le jeux c'est pareil on c'est plus comment gérer le tire.
Chez vous un ping vers ping.ovh.net vous affiche quoi ?
priv123
Message(s) : 22
Re: ping aléatoire
Message par Jereminiah » 19 Avr 2020 20:20
priv123 a écrit :Le jeux est cs:go.
Sur la connection de Voo, le ping est bien stable.. Faut voir avec les connections de Telenet.
Déjà essayé de redémarrer ton modem-routeur?
C:\Users\Jeremy>ping -t ping.ovh.net
Envoi d’une requête 'ping' sur ping.ovh.net [198.27.92.1] avec 32 octets de données :
Réponse de 198.27.92.1 : octets=32 temps=14 ms TTL=55
Réponse de 198.27.92.1 : octets=32 temps=12 ms TTL=55
Réponse de 198.27.92.1 : octets=32 temps=13 ms TTL=55
Réponse de 198.27.92.1 : octets=32 temps=15 ms TTL=55
Réponse de 198.27.92.1 : octets=32 temps=17 ms TTL=55
Réponse de 198.27.92.1 : octets=32 temps=19 ms TTL=55
Réponse de 198.27.92.1 : octets=32 temps=23 ms TTL=55
Réponse de 198.27.92.1 : octets=32 temps=10 ms TTL=55
Statistiques Ping pour 198.27.92.1:
    Paquets : envoyés = 42, reçus = 42, perdus = 0 (perte 0%),
Durée approximative des boucles en millisecondes :
    Minimum = 10ms, Maximum = 23ms, Moyenne = 14ms
Voo Duo Tatoo
Limelette : Technicolor CGA4233VOO (Mode Bridge) => Routeur Synology RT2600AC => AP WiFi Asus RT-AC87U + WiFi FON Simpl
LLN : CG3100 (Mode Bridge) => Asus RT-AX88U => Synology RT1900AC (AP) + Apple Airport (AP)
Jereminiah
Message(s) : 356
Re: ping aléatoire
Message par MisterG » 19 Avr 2020 20:34
Pinging ping.ovh.net [198.27.92.1] with 32 bytes of data:
Reply from 198.27.92.1: bytes=32 time=16ms TTL=53
Reply from 198.27.92.1: bytes=32 time=14ms TTL=53
Reply from 198.27.92.1: bytes=32 time=13ms TTL=53
Reply from 198.27.92.1: bytes=32 time=20ms TTL=53
Reply from 198.27.92.1: bytes=32 time=15ms TTL=53
Reply from 198.27.92.1: bytes=32 time=22ms TTL=53
Reply from 198.27.92.1: bytes=32 time=17ms TTL=53
Reply from 198.27.92.1: bytes=32 time=12ms TTL=53
Ping statistics for 198.27.92.1:
    Packets: Sent = 29, Received = 29, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 12ms, Maximum = 22ms, Average = 15ms
Voilà ce que j'ai.
Etant un ancien joueur, j'ai du mal à comprendre en quoi 10 ms va te faire jouer mieux à cs:go
MisterG
Message(s) : 1240
Re: ping aléatoire
Message par priv123 » 20 Avr 2020 00:40
@Jereminiah
Tu as un très bon résultat, malheuresement voo n'est pas disponible j'ai vérifier via leur site.
@MisterG
Faut s'y connaître et avoir un bon niveau.
J'ai environs 17 ans d'expérience continu (cs, czéro, cs:s, cs:go).
Avoir un ping le plus bas possible c'est vraiment top.
Le problème ici, c'est l'instabilité, je suis près à avoir 20 ping stable que 12 ping instable avec des montés à 20-30..
Ton résultat est nettement mieux que le mien en cet période confinement (en heure pleine), environ à la même heure j'oscillais énormement entre 15-30 contrairement à tes 16 plus ou moins stable.
priv123
Message(s) : 22
Re: ping aléatoire
Message par MisterG » 21 Avr 2020 15:32
priv123 a écrit :@Jereminiah
@MisterG
Top 5 Européen par équipe en CTF à Unreal Tournament c'est suffisant ? ;)
Si j'avais mon ping d'aujourd'hui à cette époque là j'aurais été plus que content.
Telenet a toujours eu un mauvais ping avec OVH
MisterG
Message(s) : 1240
Retour vers Telenet
