NO IP FOR NAT (Resolu)
Message par Mobius79 » 15 Mars 2012 01:39
Depuis quelque jours j' ai le message NO IP FOR NAT dand mon log de securite de mon routeur et je le fais deconnecter occasionelment qaund je joue en ligne. Ci-dessous un extrait du log.
Comment puis-je remédier a ce petit problème? merci.
ar 15 00:28:02 2012 Firewall Setup Firewall internal Firewall configuration succeeded
Mar 15 00:28:02 2012 Firewall Setup Firewall internal No IP for NAT - connections may fail [repeated 2 times, last time on Mar 15 00:28:02 2012]
Mar 15 00:28:02 2012 Firewall Setup Firewall internal Starting firewall configuration
Mar 15 00:26:41 2012 Firewall Setup Firewall internal Firewall configuration succeeded
Mar 15 00:26:41 2012 Firewall Setup Firewall internal No IP for NAT - connections may fail [repeated 2 times, last time on Mar 15 00:26:41 2012]
Mar 15 00:26:41 2012 Firewall Setup Firewall internal Starting firewall configuration
Mar 15 00:02:29 2012 Firewall Setup Firewall internal Firewall configuration succeeded
Mar 15 00:02:29 2012 Firewall Setup Firewall internal No IP for NAT - connections may fail [repeated 2 times, last time on Mar 15 00:02:29 2012]
Mar 15 00:02:29 2012 Firewall Setup Firewall internal Starting firewall configuration
Mar 14 23:36:59 2012 Firewall Setup Firewall internal Firewall configuration succeeded
Mar 14 23:36:59 2012 Firewall Setup Firewall internal No IP for NAT - connections may fail [repeated 2 times, last time on Mar 14 23:36:59 2012]
Mar 14 23:36:59 2012 Firewall Setup Firewall internal Starting firewall configuration
Mar 14 23:36:56 2012 Firewall Setup Firewall internal Firewall configuration succeeded
Mar 14 23:36:56 2012 Firewall Setup Firewall internal No IP for NAT - connections may fail [repeated 2 times, last time on Mar 14 23:36:56 2012]
Mar 14 23:36:56 2012 Firewall Setup Firewall internal Starting firewall configuration
Mar 14 23:36:38 2012 Outbound Traffic Blocked - NAT Error: No free NAT IP [62] NAT Error: No free NAT IP:
Mar 14 23:36:38 2012 Firewall Setup Firewall internal Firewall configuration succeeded
Mobius79
Message(s) : 8
Re: NO IP FOR NAT
Message par Charles_AlphaNetworks » 15 Mars 2012 10:44
Mobius79 a écrit :Bonjour,
peux-tu m'envoyer des coordonnées + nom/prénom par MP que je puisse regarder ?
merci d'avance.
Message(s) : 116
Retour vers Billi
Utilisateur(s) parcourant ce forum : Google Feedfetcher
