philippe_d a écrit :Above report shows some strange numbers:
Based on the attenuation (3.3 db) you seem to be very close to the ROP (confirmed by the "estimated" line lenght).
However, your SNR seems much too low for this line lenght. Increasing your speed to 50mbps will result in a borderline low SNR (close to the modem max). Hence I would be surprised if DLM will put you on 50mbps (realistically you may end up at 40 mbps).
You should check your internal cabling (starting from the entry point up to where the modem is connected), making sure your installation is conform the rules, and you do not have any stubs ...
Thanks Philippe for your message !
I will check that... But I think it's a short cable (max 1,5m) from Belgacom...
