GutsCrush3R a écrit :Pour la modification/création du MTU depuis le registre :
http://www.dslvalley.com/dossiers/mtu/mtu.php
GutsCrush3R a écrit :Et ça c'est quoi ?
En changeant la valeur dans la page de configuration du modem, ça modifie la valeur dans le registre.
Il n'y a pas de conflit entre le deux (si c'est de ça dont tu parlais avec ta "transformation de taille").
# ping -s 1250 belnet.be
PING belnet.be (193.190.198.53) 1250(1278) bytes of data.
1258 bytes from loba.belnet.be (193.190.198.53): icmp_seq=1 ttl=57 time=40.3 ms
1258 bytes from loba.belnet.be (193.190.198.53): icmp_seq=2 ttl=57 time=41.6 ms
1258 bytes from loba.belnet.be (193.190.198.53): icmp_seq=3 ttl=57 time=41.7 ms
1258 bytes from loba.belnet.be (193.190.198.53): icmp_seq=4 ttl=57 time=41.6 ms
1258 bytes from loba.belnet.be (193.190.198.53): icmp_seq=5 ttl=57 time=41.2 ms
1258 bytes from loba.belnet.be (193.190.198.53): icmp_seq=6 ttl=57 time=40.7 ms
1258 bytes from loba.belnet.be (193.190.198.53): icmp_seq=7 ttl=57 time=43.3 ms
1258 bytes from loba.belnet.be (193.190.198.53): icmp_seq=8 ttl=57 time=40.8 ms
1258 bytes from loba.belnet.be (193.190.198.53): icmp_seq=9 ttl=57 time=41.3 ms
1258 bytes from loba.belnet.be (193.190.198.53): icmp_seq=10 ttl=57 time=40.5 ms
--- belnet.be ping statistics ---
10 packets transmitted, 10 received, 0% packet loss, time 13053ms
rtt min/avg/max/mdev = 40.354/41.346/43.309/0.842 ms
# ping -s 1350 belnet.be
PING belnet.be (193.190.198.53) 1350(1378) bytes of data.
1358 bytes from loba.belnet.be (193.190.198.53): icmp_seq=6 ttl=57 time=44.2 ms
1358 bytes from loba.belnet.be (193.190.198.53): icmp_seq=8 ttl=57 time=43.7 ms
1358 bytes from loba.belnet.be (193.190.198.53): icmp_seq=27 ttl=57 time=41.4 ms
1358 bytes from loba.belnet.be (193.190.198.53): icmp_seq=56 ttl=57 time=41.8 ms
58 packets transmitted, 4 received, 93% packet loss, time 57011ms
rtt min/avg/max/mdev = 41.425/42.797/44.237/1.212 ms
Nyctalopyman a écrit :Tu fais un ping de taille proche de 1300 octets: si tu essayes au-dessus de ça et que ça continue à passer, c'est que tu n'as pas le problème. Moi j'ai ça:# ping -s 1250 belnet.be
et puis ça:# ping -s 1350 belnet.be
Sous Windows ? Démarrer -> Exécuter -> cmd -> OK -> ping -n 10 -l 1250 belnet.beMike25 a écrit :comment on fait ça???
La procédure a faire.?
Envoi d'une requête 'ping' sur belnet.be [193.190.198.53] avec 1250 octets de données :
Réponse de 193.190.198.53 : octets=1250 temps=36 ms TTL=58
Réponse de 193.190.198.53 : octets=1250 temps=35 ms TTL=58
Réponse de 193.190.198.53 : octets=1250 temps=34 ms TTL=58
Statistiques Ping pour 193.190.198.53:
Paquets : envoyés = 10, reçus = 10, perdus = 0 (perte 0%),
Durée approximative des boucles en millisecondes :
Minimum = 34ms, Maximum = 36ms, Moyenne = 35ms
ping -n 10 -l 12500 belnet.be
Envoi d'une requête 'ping' sur belnet.be [193.190.198.53] avec 12500 octets de données :
Réponse de 193.190.198.53 : octets=12500 temps=267 ms TTL=58
Réponse de 193.190.198.53 : octets=12500 temps=266 ms TTL=58
Réponse de 193.190.198.53 : octets=12500 temps=268 ms TTL=58
Réponse de 193.190.198.53 : octets=12500 temps=279 ms TTL=58
Réponse de 193.190.198.53 : octets=12500 temps=269 ms TTL=58
Minimum = 266ms, Maximum = 279ms, Moyenne = 268ms
VincentL a écrit :Bonsoir,Sous Windows ? Démarrer -> Exécuter -> cmd -> OK -> ping -n 10 -l 1250 belnet.beMike25 a écrit :comment on fait ça???
- Code : Tout sélectionner
